  3. How to map output of checkDesign to db*** command ?
  • Subscribers 92
  • Views 13270
KEVIN SCREEN
KEVIN SCREEN over 14 years ago
Hi , 'checkDesign' is fast and complete. However, some of them are not detail information. Hence, I want to write some code to dump more information about it. I need to know is there any db*** command can get the data of output from checkDesign ? ex: checkDesng ... Checking IO Pins..... Floating/Unconnected IO Pins = 2 Checking constraints (guide/region/fence)..... Is there any db*** to get the value ,2, of 'Floating/Unconnected IO Pins'. ? Thanks a lot \Kevin
