  3. Save Special Routing
  • Subscribers 93
  • Views 13989
Vio719
Vio719 over 14 years ago
Hi , Am working in Toplevel floor plan for a design, i edited certain routes manually using my top layer. Now i want to save those routes only as an .spr or any other format which is readable for encounter. So tat next time i can use this in my design. How can i do this without disturbing other routes in my design. If i save it using defOut -routed -selected it is changing certain other things also. Thnx in advance, Vio
  • Kevin P Thomas
    Kevin P Thomas over 14 years ago
     editSelect  -nets xxx
     editSelectVia -nets xxx
    defOut -routing -selected xxx.def.gz
    If those are special nets only you can specify
    defIn  -specialnets xxx.def.gz
    otherwise
     defIn  -nets xxx.def.gz
     This will  reads the NETS section of the DEF file
