  3. differences between routers
  • Subscribers 92
  • Views 13725
DSubbu
DSubbu over 13 years ago
hi all,
Can any one please let me know clear difference between global route ,detailroute ,globalDetailroute in Soc encouter tool as per its routing procedures . .
Thanks ,
subbu
  • Kari
    Kari over 13 years ago
     Hi Subbu,
    Global route is the first step in routing the design, kind of a planning stage. The design is broken up into boxes called gcells and the general plan of what wires will go through which gcells in order to connect up all the nets is determined. This does not result in routed wires you can actually see. The detail route is exactly what it sounds like, the actual routing of the wires. This step will result in wires that you can see. The most common way to route a design is to do both of these steps in one command, globalDetailRoute.
    Hope that helps,
    - Kari
