  3. Can dbShape handle negative coordinates?
  • Subscribers 93
  • Views 14951
pdgeek
pdgeek over 13 years ago
I have been using dbGet and dbShape to identify and generate complicated rectilinear shapes in our chip floorplan. Everything was working great until this morning we realized we needed to have our chip 0,0 origin at die center and not at the lower left corner of the padring. I thought no problem I can easily shift or define the origin to be die center using the  -fplanOrigin center switch to the floorPlan and this did define the origin as desired. But my floorplan tcl code died while executing dbShape which had previously worked with a lower left chip origin.
It looks like the problem is that dbShape can not handle negative coordinates. For example this works:
encounter 60> dbshape [list 0 0 10 10] SIZE 10
{-10 -10 20 20}
but this does not
encounter 65> dbshape [list -1 -1 9 9] SIZE 10
**ERROR: (ENCDBTCL-203):        '-1 -1 9 9' is not a valid option.
The correct command usage is:
Usage: dbShape [-help] [-d] [-step <step>] [-output <polygon|rect|hrect>]
             <shapeList> [AND <shapeList> | ANDNOT <shapeList> | OR <shapeList> | XOR <shapeList>
             | SIZE <value>| BBOX | MOVE {<dx> <dy>}] ...
Anybody see what I am missing? Maybe there is some trick for passing in the negative values into dbShape although interesting that the first command properly gave the SIZE 10 output box with correct coords, some being negative.
Thanks for any help anyone might be able provide.
Tom
  • jgentry
    jgentry over 13 years ago
    I've ht this before too. Easy to fix. Keep I mind that dbShape want to work on a list of lists. It is interpreting the first neg number as an option. Add another list level and it should work. dbShape [list [list -1 -1 9 9]] SIZE 10
  • pdgeek
    jgentry,
    Thanks for your response. I also got the same tip/hint from Cadence support late yesterday. Using the extra enclosing list level solved the problem.
    The question I posed to cadence support is whether dbShape can be enhanced to not allow this to happen, ie. TCL code that works with single list with positive first coordinate but then needs an extra enclosing list when first coord is negative?
    Now that I know the issue I am fine. Thinking of the user community at large is this something I should have known somehow and therefore there is no real issue with dbShape and how it works for future users who might stumble upon this same thing?
    Thanks again,
    Tom
  • jgentry
    Yeah, I think that the original, non-negative 1-level list should have also thrown an error immediately. My guess is they were trying to be flexible with the way people specified shape lists but didn't properly handle the case when a negative number was specified. I still think it probably has to do with the way theoptions (-option) are specified, probably got caught up in their argument parser and died in a 'default' clause.
