  3. ILM in encounter 8.1
  • Subscribers 92
  • Views 14543
DavidMZ
DavidMZ over 13 years ago
Hi there,
as said in the title I'm trying to use ILM (Interface Logic Model) in encounter 8.1.
In that aim I made a simple design consisting of one single instance of a block, which block is using ILM.
My problem is, when I try to "placeDesign" as stated in the example top-level implementation flow using ILMs chapter of the encounter manual, I see that the stdcells INSIDE the block are placed at their "best" locations, which means:
                      -different locations than what I had in the original block
                      -illegal locations (->stacked stdcells, stdcells in the block power ring)
 Of course I had to do a "flattenIlm" after the "placeDesign" command in order to see the stdcells.
 Is it a normal behavior?
 Thanks you for your answers,
David
  • DavidMZ
    A recent tentative of modifying the .def files inside the ILM directory didn't change a thing to my problem (I replaced all the "PLACED" statements by "FIXED" ones, since I figured out I had many "PLACED" instances in the .def, even though everything is clearly "fixed" in my original design...)
    Also, my few tentatives of performing an STA were also unsuccesful. I do have a .sdc file for the top, and I also wrote out .sdc files when generating the ILM module, but seeing the results of an STA I assume the ILM has no timing information. Taking into account this post: http://www.cadence.com/Community/forums/p/16435/968523.aspx#968523, I'm currently considering giving up using ILMs since they are too unreliable. This being said to warn future users (nevertheless, I would be very glad to be wrong!)
