  3. Getting associated library cell name for a instance in ...
  • Subscribers 93
  • Views 19311
Getting associated library cell name for a instance in ets
abhingp01
abhingp01 over 13 years ago
Is it possible to get associated library cell name for any given instance in design.
I can see 'get_cells' which returns instance name and 'get_lib_cells' which returns the cell names matching the regular expression.
In 'report_timing' it prints the  cell name but the same is not made available in collection.
Please help me with same and correct me if I am wrong.
Abhi
  • jgentry
    jgentry over 13 years ago
    Try: get_property [get_cells $instName] ref_name, or maybe get_attribute, I forget which is used in each EDA tool.
  • abhingp01
    I tried that already and went through all the option that collection of type 'cell' or collection of type 'pin'provides.
    Actually logically speaking 'get_cells' should return library cell name but here it returns instance name which I can even get it by triming pin name :(
  • jgentry
    Too bad. I usually revert back to db-access when nothing else works. Something like: dbCellName [dbInstCell [dbGetInstByName [get_object_name $col]]]
  • abhingp01
    Got it:
    ref_lib_cell_name
    This will give associated library cell name.
