  3. How to dump specific nets in SOCe?
  • Subscribers 92
  • Views 14172
anil chatrathi
anil chatrathi over 13 years ago
I want to dump specific power nets  to be dumped and used in the next design.
Can any one suggest how to do that?
Anil
  • Kari
    Kari over 13 years ago
    select the nets you want to keep, then try:
    defOut -selected -routing mynets.def
    load that in and double-check that it looks right - make sure you got all the vias you need.
    If the vias are not there, then you may need to select them too before the defOut. let us know how it works!
    - Kari
  • anil chatrathi
    Thank you kari.
    As you said,  Selecting nets and dumping is not working. We need to select nets and and vias to dump in def.
    Anil
  • Kari
    Thanks for reporting back! Glad you got it working.
     - Kari
