  3. **DIAG message while running a db command
  • Subscribers 92
  • Views 13960
tiEngr
tiEngr over 13 years ago
Hi All,
This is just section of my script that is creating this DIAG message.  In short Iam trying to write every net inside a module. Here I picked one of the module from the design. What I see that this message occurs at the begining of dbForEachCellNet then it does what it suppose to do. Not sure what to make of this message or how to remove it.
Irfan
dbForEachCellNet 0x1b7b3c38 cellNetPtr {
    puts "[dbCellName 0x1b7b3c38] [dbVNetName $cellNetPtr] "
encounter 77> dbForEachCellNet 0x1b7b3c38 cellNetPtr { puts "[dbCellName 0x1b7b3c38] [dbVNetName $cellNetPtr] "}
**DIAG[dbTclCmd.c:3148:dbiForEachCellNetCmd]: Assert "!dbmIsNetVNet(dbmCellNetList((dbsCell *)p))"
syncstage_54_0 sync
syncstage_54_0 clk
syncstage_54_0 async
syncstage_54_0 reset_N
syncstage_54_0 test_si
syncstage_54_0 test_se
syncstage_54_0 SPCASCAN_N314
syncstage_54_0 fmonDiagReg_0
syncstage_54_0 FE_OFN23_n1
syncstage_54_0 FE_OFN254_softReset_N
  • wally1
    wally1 over 13 years ago
    Can you try using dbGet? The following will report the hierarchical nets for module "iu":
      set modName "iu"
      set modPtr [dbGet -p head.allCells.name $modName]
      set modNets [dbGet $modPtr.hInst.hNets.name]
      puts $modNets
    Brian
  • tiEngr
    Thanks Brain,
     This wiil work too.  So is it not recomended to use dbForEach* commands any more.
    Irfan
  • wally1
    It's recommended to use dbGet as it is easier to use than trying to remember all the different db* functions. Here are some solutions which are handy for learning dbGet:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11618132
    mber=11585414
    Brian
