  3. Encounter as a LEF viewer ?
  • Subscribers 93
  • Views 14654
Anjana
Anjana over 13 years ago
I am working on a design for which we use a memory from a customer. We would like to see the pin locations / assignments in the memory lef that they dropped . But  I have not yet received a pre -synthesised netlist from the front end yet ,otherwise i could load it up and check. Is there any option in encounter wherein I could load the lef and see how the pin assignments are ?.
  • wally1
    wally1 over 13 years ago
    One solution is create a simple Verilog netlist that instantiates the memory such as:
        module top ();
        memoryName inst0();
        endmodule
    Then import that into Encounter in place of the synthesize netlist. You can then view the memory in the floorplan.
    Brian
  • jgentry
    jgentry over 13 years ago
    I do this all the time.  There is no specific LEF viewer that I know of (perhaps somebody else does?).  However, it is relatively easy to create a wrapper Verilog around this cell, you don't even need to specify any ports or connectivity, just instantiate the cell.  Then load it up like any other design.  You'll need to open the color menu and expose pins and route blockages in the wires tab.  There are no actual wires when you view the LEF this way.
     Hope that helps,
    Jason
  • Anjana
    Thank you very much , Brian & Jason. I shall try that out.
