  3. How to avoid a group of cell from getting optimised
  • Subscribers 93
  • Views 13813
crystee
crystee over 13 years ago
The thing is the design contain some memory, but memory complier is not available for hardening the memory. While optimising the rest of the logic, the memory which is realised as flops are also optimised. Reason is SoC encounter see these flops as just instances/standard cell.
 As a result, timing cant be closed at desired frequency & is also leading to very high setup & hold violations.
So how to optimise the rest of the design without touching the memory part.
  • fitz
    fitz over 13 years ago
    set_dont_touch
    set_dont_touch object_list [true | false]
    Prevents the specified object from being modified during optimization.
    When you specify a net, all the connecting instances are affected by the set_dont_touch command.
    Parameters
    true | false
    Sets or removes the set_dont_touch attribute for the specified object_list.
    Default: true
    object_list
    Specifies the list of instances, nets, library cells, or submodules.
