  3. How to clear connectivity error on special routes
  • Subscribers 93
  • Views 14864
vimalraj
vimalraj over 13 years ago
hai
i have done a PnR for my design
i have 4 macros in my design, When i place them inside my core area and do special routing for VDD VSS nets, i find some nets are dangling and are open nets, i have also applied halo's for every blocks eventhough i find some error as shown in my attachment
so please help me to overcome this error..floorplan
  • diablo
    diablo over 13 years ago
    The image you have attached looks like complete routing is done instead of just sroute. If you have issue with sroute, check you Macro LEF to see if those power/ground pins that you are trying to sroute are indeed defined as POWER/GROUND. Secondly, you need to verify that GlobalnetConnect has been applied to power/ground pin of your MACRO. For floating signal nets, you could check the netlist if there is a net connection.
  • vimalraj
     thank you diablo
    I Have cleared that error
