  3. Doubt regarding power planning
  • Subscribers 92
  • Views 13846
selvam27
selvam27 over 13 years ago
Currently I'm working on 40nm technology and the LEF has 7 metal layers named as M1 to M7. I have choosen M1 and M2 for POWER ring and stripes.  Which metal is better for POWER ring and stripes ? Could you please explain me with an simple example?
  • KarelH
    KarelH over 13 years ago
    Hi Selvam,
    please, check this solution, especially attached pdf. Usually, the higher layers for power routing are better, because they have lower resistance. Also, power stripes in M1, M2 will block std cell pins.
    Karel
    http://support.cadence.com/wps/myportal/cos/COSHome/viewsolution/!ut/p/c5/dY1broIwFEXH4gDMKeiF9rMC8oqA5WHtD0FivASkgAQJoxcH4NqfKzsLBKxri6l6FGMl26IBDkLLFdU2FH-PSGgEGLlYC3yWWWgFLt-HlqMfUARXEPrXq6qCEbGPyQG5hu96WN-pyNcga-XwXEsJcKeUsynpw6Qm9QgvzicZOe5bv9VZ71FZNBEZuIGdE54ZYV2illY-xg0u-ykVbKp3LzrV53fMmj-Ph3OZHsbLdZ8Iu7LCfNlGpI-XxEDOcKfslm5d06u7Sc_7_wVvIHDk8w5d3S5HTDcfaxDlYg!!/dl3/d3/L2dBISEvZ0FBIS9nQSEh/
  • selvam27
    Thanks for your valuable reply.
