  3. how to add a global net
  • Subscribers 93
  • Views 16757
anil chatrathi
anil chatrathi over 13 years ago
I have a requirement add dummy power net which has to conected to macro pins.
with "addNet  -physical only "   I could  able to create the net. But it is not created as global net.
When I do a globalnetconnection to the macro pins I am getting an error that the net created is not a global net.
can any one suggest me to  add a global net and conect it to a pin    in encounter.
Thanks and Regards, Anil
  • wally1
    wally1 over 13 years ago
    Hi Anil,
    Try the following depending on whether it is power or ground:
    addNet -physical vddcore
    addNet -physical gndcore
    setNet -net vddcore -type special
    setNet -net gndcore -type special
    dbSetIsNetPwr vddcore
    dbSetIsNetGnd gndcore
    More info is in solution:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11732912
    Brian
  • anil chatrathi
    Thank You, Brian.
  • Kirtesh Tiwari
    Kirtesh Tiwari over 11 years ago
    wally1 said:
    Hi Anil,
    Brian
    Hi Brian ,
    Solution id seems to be incorrect as it is opening some hold analysis solution can you please provide corect one or can you give subject of this solution.
    Kirtesh
  • wally1
    wally1 over 11 years ago
    Sorry, Kirtesh. Here is the correct one:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11796740
    Brian
