  3. CPF create retention and isolation Error...
  • Subscribers 92
  • Views 13542
yasir khan
yasir khan over 13 years ago
I am getting 2-Errors while synthesizing my design with CPF (PSO) method on RC compilor.....
1) create_state_retention_rule
2) create_isolation_rule
while in my CPF design part i decleared them as...........
 create_isolation_rule -name iso1 -from   PD_xbus_hw_idct_rtl  -isolation_condition {powercontrol.iso_en}
 create_isolation_rule -name iso2 -to   PD_default  -isolation_condition { powercontrol.iso_en} -isolation_output high
create_state_retention_rule -name st1 -domain PD_xbus_hw_idct_rtl -restore_edge {!powercontrol.ret_en}
the log file is stated as ......result.
Statistics of CPF commands processed
    Command                              failed  successful  unsupported  total  runtime
 1. create_global_connection          0           0            6      6     0.00
 2. create_ground_nets                  0           0            1      1     0.00
 3. create_isolation_rule                 2           0            0      2     0.00
 4. create_nominal_condition          0           2            0      2     0.00
 5. create_power_domain               0           2            0      2     0.00
 6. create_power_mode                  0           2            0      2     3.00
 7. create_power_nets                    0           0            3      3     0.00
 8. create_power_switch_rule          0           0            1      1     0.00
 9. create_state_retention_rule        1           0            0      1     0.00
10. define_always_on_cell              0           1            0      1     0.00
11. define_isolation_cell                 0           4            0      2     0.00
12. define_library_set                     0           1            0      1     0.00
13. define_power_switch_cell          0           0            1      1     0.00
14. define_state_retention_cell        0           2            0      1     1.00
15. end_design                              0           1            0      1     0.00
16. set_design                              0           1            0      1     0.00
17. set_hierarchy_separator           0           1            0      1     0.00
18. set_power_unit                        0           1            0      1     0.00
19. update_isolation_rules              0           1            0      1     0.00
20. update_nominal_condition         0           1            0      1     0.00
21. update_power_domain              0           2            0      2     0.00
22. update_power_mode                0           2            0      2     0.00
23. update_power_switch_rule        0           0            1      1     0.00
Completed processing all CPF commands (runtime  5.00).
rc:/designs/topmodule> cd
rc:/> clear
any suggestion...
