  3. EDI installation help
  • Subscribers 92
  • Views 15783
smachha
smachha over 13 years ago
Hi all,
I am new to digital implementation.Recently,I installed EDI11.10.000 RHEL5 (lin86) base through iscape. I selected install only option as i dont want the downloaded file.
After installation it went for the oasis configuratio. after this i see a "installed"in iscape.But when i tried the command /tools/cadence/EDI/bin/velocity .. it is giving an error
" bash: /tools/cadence/EDI/bin/velocity: /bin/ksh: bad interpreter: No such file or directory "
can somebody tell me how to proceed next and how to open the encounter and what are all the steps to follow next.
Thanks in advance.
 Sunil.
  • wally1
    wally1 over 13 years ago
    Hi Sunil,
    Run "checkSysConf EDI111" to make sure you have the required patches installed. Based on the following thread the ksh package is missing:
    http://www.cadence.com/community/forums/T/22687.aspx
    Brian
  • smachha
     HI Brian,
    Thanks for the reply. I did't find the checkSysConf at my install path, so i downloaded it from the cadence site. But when i am running  XXX/tools.lnx86/bin/checkSysConf release EDI11 , it is giving the error  " theHost: Undefined variable. "
    can you please help me here.
    sunil
  • wally1
    Hi Sunil,
    If you open the checkSysConf file you'll see the variable theHost is supposed to be set to the output of 'hostname'. If you type hostname at the Linux prompt does it report the machine name?
    This is probably something better to debug through Customer Support. Can you open a Service Request through http://support.cadence.com?
    Brian
