  3. The setup violation for the inclkSrc2reg paths in the layout...
  • Replies 14
  • Subscribers 94
  • Views 23357
The setup violation for the inclkSrc2reg paths in the layout designed by encounter
zhengyudennis
zhengyudennis over 14 years ago
Hi everyone,
  I am a learner of encounter (cadence) and meet the setup violation on the inclkSrc2reg group, which is shown as follows:
Path 1: VIOLATED Setup Check with Pin \DFF_1048/Q_reg /CLK
Endpoint:   \DFF_1048/Q_reg /D (^) checked with  leading edge of 'CK'
Beginpoint: g35                (v) triggered by  leading edge of 'CK'
Path Groups:  {inclkSrc2reg}
Other End Arrival Time          0.582
- Setup                         0.190
+ Phase Shift                   5.000
- Uncertainty                   0.100
= Required Time                 5.292
- Arrival Time                 13.369
= Slack Time                   -8.077
     Clock Rise Edge                      0.000
     + Input Delay                        0.200
     + Drive Adjustment                   0.717
     = Beginpoint Arrival Time            0.917
     Timing Path:
     |    Instance     |    Arc     |   Cell   |  Slew | Delay | Arrival | Required |
     |                 |            |          |       |       |  Time   |   Time   |
     |                 | g35 v      |          | 1.101 |       |   0.917 |   -7.160 |
     | U9357           | A v -> Y ^ | INVX1    | 3.186 | 5.666 |   6.583 |   -1.494 |
     | U9293           | A ^ -> Y v | INVX1    | 1.807 | 1.734 |   8.317 |    0.240 |
     | U8504           | A v -> Y ^ | INVX1    | 3.386 | 2.575 |  10.892 |    2.814 |
     | U8477           | A ^ -> Y v | INVX1    | 1.729 | 1.346 |  12.237 |    4.160 |
     | U6039           | A v -> Y ^ | OAI21X1  | 0.709 | 0.726 |  12.964 |    4.886 |
     | \DFF_1048/U4    | B ^ -> Y v | MUX2X1   | 0.710 | 0.171 |  13.135 |    5.057 |
     | \DFF_1048/U3    | A v -> Y ^ | INVX1    | 0.183 | 0.235 |  13.369 |    5.292 |
     | \DFF_1048/Q_reg | D ^        | DFFPOSX1 | 0.183 | 0.000 |  13.369 |    5.292 |
     + Drive Adjustment                   0.003
     = Beginpoint Arrival Time            0.003
     Other End Path:
     |                 | CK ^       |          | 0.021 |       |   0.003 |    8.081 |
     | CK__L1_I0       | A ^ -> Y ^ | CLKBUF2  | 0.043 | 0.086 |   0.089 |    8.167 |
     | CK__L2_I1       | A ^ -> Y ^ | CLKBUF3  | 0.058 | 0.124 |   0.213 |    8.290 |
     | CK__L3_I6       | A ^ -> Y ^ | CLKBUF2  | 0.040 | 0.094 |   0.307 |    8.384 |
     | CK__L4_I16      | A ^ -> Y ^ | CLKBUF3  | 0.039 | 0.116 |   0.424 |    8.501 |
     | CK__L5_I48      | A ^ -> Y ^ | CLKBUF1  | 0.047 | 0.071 |   0.495 |    8.572 |
     | CK__L6_I239     | A ^ -> Y ^ | CLKBUF1  | 0.069 | 0.087 |   0.581 |    8.659 |
     | \DFF_1048/Q_reg | CLK ^      | DFFPOSX1 | 0.069 | 0.001 |   0.582 |    8.660 |
Here, g35 is the input pin. I am a little bit confused that why the delay of U9357 (only a inverter) can be 5.666 ns. Further, all the setup violations happen on the inclkSrc2reg group. Can somebody tell me how to solve such problem? Thanks very much!
Best,
Dennis
  • zhengyudennis
    The max_fanout constraint is added in the script for DC compilation
    the value of max_transition constraint is specified according to your clock period and technology file.
    I am also a learner, so we can have a discuss about it.
  • zhengyudennis
    One more thing to bother you. Sorry about that.
    From the CTS synthesis in the encounter, I found that the library setup time is strongly related to the clock transition time. I get the following result when 'set_clock_transition 0.5' and the clock period is 3.3 ns.
    Path 1: VIOLATED Setup Check with Pin \DFF_993/Q_reg /CLK
    Endpoint:   \DFF_993/Q_reg /D (^) checked with  leading edge of 'CK'
    Beginpoint: RESET             (^) triggered by  leading edge of 'CK'
    Other End Arrival Time          0.995
    - Setup                         6.838
    + Phase Shift                   3.300
    - Uncertainty                   0.100
    = Required Time                -2.643
    - Arrival Time                  2.523
    = Slack Time                   -5.166
         + Input Delay                        0.200
         + Drive Adjustment                   0.010
         + Network Insertion Delay            1.000
         = Beginpoint Arrival Time            1.211
         Timing Path:
         |                | RESET ^    |          | 0.005 |       |   1.210 |   -3.955 |
         | U6196          | A ^ -> Y v | INVX1    | 0.049 | 0.046 |   1.256 |   -3.909 |
         | U6219          | A v -> Y ^ | INVX1    | 0.086 | 0.081 |   1.338 |   -3.828 |
         | U6255          | A ^ -> Y v | INVX1    | 0.091 | 0.094 |   1.432 |   -3.734 |
         | U6254          | A v -> Y v | BUFX2    | 0.075 | 0.098 |   1.530 |   -3.636 |
         | U3685          | C v -> Y ^ | NOR3X1   | 0.181 | 0.128 |   1.658 |   -3.508 |
         | U4769          | A ^ -> Y v | INVX1    | 0.050 | 0.097 |   1.755 |   -3.411 |
         | U6160          | A v -> Y ^ | INVX1    | 0.022 | 0.042 |   1.797 |   -3.369 |
         | U5856          | A ^ -> Y v | INVX1    | 0.044 | 0.042 |   1.839 |   -3.327 |
         | U5855          | A v -> Y ^ | INVX1    | 0.159 | 0.119 |   1.958 |   -3.208 |
         | U5756          | A ^ -> Y v | INVX1    | 0.098 | 0.121 |   2.079 |   -3.087 |
         | U5533          | A v -> Y ^ | INVX1    | 0.142 | 0.130 |   2.209 |   -2.956 |
         | U2094          | C ^ -> Y v | AOI22X1  | 0.143 | 0.050 |   2.260 |   -2.906 |
         | U4256          | B v -> Y v | AND2X2   | 0.037 | 0.073 |   2.333 |   -2.833 |
         | U4257          | A v -> Y ^ | INVX1    | 0.478 | 0.017 |   2.350 |   -2.815 |
         | \DFF_993/U4    | B ^ -> Y v | MUX2X1   | 0.091 | 0.135 |   2.486 |   -2.680 |
         | \DFF_993/U3    | A v -> Y ^ | INVX1    | 0.000 | 0.037 |   2.523 |   -2.643 |
         | \DFF_993/Q_reg | D ^        | DFFPOSX1 | 0.000 | 0.000 |   2.523 |   -2.643 |
         Other End Path:
         |                | CK ^       |          | 0.022 |       |   0.004 |    5.169 |
         | CK__L1_I0      | A ^ -> Y ^ | CLKBUF2  | 0.014 | 0.069 |   0.073 |    5.239 |
         | CK__L2_I0      | A ^ -> Y ^ | CLKBUF2  | 0.016 | 0.070 |   0.143 |    5.309 |
         | CK__L3_I0      | A ^ -> Y ^ | CLKBUF3  | 0.016 | 0.097 |   0.240 |    5.406 |
         | CK__L4_I0      | A ^ -> Y ^ | CLKBUF3  | 0.030 | 0.106 |   0.346 |    5.511 |
         | CK__L5_I0      | A ^ -> Y ^ | CLKBUF2  | 0.039 | 0.089 |   0.435 |    5.600 |
         | CK__L6_I0      | A ^ -> Y ^ | CLKBUF1  | 0.337 | 0.239 |   0.674 |    5.839 |
         | CK__L7_I9      | A ^ -> Y ^ | CLKBUF2  | 0.397 | 0.312 |   0.986 |    6.152 |
         | \DFF_993/Q_reg | CLK ^      | DFFPOSX1 | 0.398 | 0.009 |   0.995 |    6.161 |
     So, How can I reduce the library setup time in encounter? Thanks very much!
  • Scrivner
    Scrivner over 14 years ago
    In your CTS config file *.ctstch you will need to reduce your max clock transition.
  • zhengyudennis
    I found that if I reduce the clock transition time in DC, than the synthesis procedure will be very difficult to finish. It seems that the larger clock transition time, the larger library setup time. Is it right?
