  3. How to dump out blockages into a file
  • Subscribers 93
  • Views 18070
Anuragjn
Anuragjn over 13 years ago
Hi all,
I want to dump out placement blockage (hard,soft,partial) into file is there any utility in encounter gui to do so,as we can do to dump out the marco place,By using save "place" utility in gui
and vice versa to dump routing blockages.
 So can any one guide me if there's any utility in GUI and even command based woul be good .
Anurag
  • Kari
    Kari over 13 years ago
    You can write them out in a DEF file:
    defOutBySection -noComps -noNets -pBlockages -rBlockages myBlockages.def
    pBlockages is the placement blockages (all kinds) and rBlockages is the routing blockages.
  • Anuragjn
    HI Kari,
    Thanks for the Command
    But Partial Blockages are not being dumped ,I tried even loading the DEF file but the partial blockage are no where seen
  • kazad
    kazad over 13 years ago
    This is a tcl command-based solution for dumping out the placement (including soft, partial & hard) /routing blockages from Encounter session:
    # Procedure to save blockages into tcl command
    # Usage: saveBlockages -type <placement | routing | all> -outFile <output_tcl_file>
    proc saveBlockages {args} {
        global env
        # Get blockage type
        if {[regexp {\-type} $args]} {
     set blockageType [lindex $args [expr [lsearch $args -type] + 1]]
        # Get output file
        if {[regexp {\-outFile} $args]} {
     set outfile [lindex $args [expr [lsearch $args -outFile] + 1]]
        # Help
        set helpString "Usage : saveBlockages \
                                    \-type <placement | routing | all> \
                                    \-outFile <file_name> \
                                    \-help"
        if {[regexp {\-help} $args] || $args == ""} {
            puts $helpString
            return 0
        # Main code
        set f [open $outfile w]
        # Placement blockages
        if {$blockageType == "placement" || $blockageType == "all"} {
     foreach pblkgType [dbGet -u top.fPlan.pBlkgs.type] {
         foreach obsPtr [dbGet -p top.fPlan.pBlkgs.type $pblkgType] {
      set obsName [dbGet $obsPtr.name]
      set box [exl [dbGet $obsPtr.boxes]]
      switch -- $pblkgType {
          "hard" {
       puts $f "createObstruct -box $box -name $obsName"
          "partial" {
       set density [dbGet $obsPtr.density]
       puts $f "createDensityArea -name $obsName $box $density"
          "soft" {
        # Routing blockages
        if {$blockageType == "routing" || $blockageType == "all"} {
     foreach rBlkPtr [dbGet top.fPlan.rBlkgs] {
         set name [dbGet ${rBlkPtr}.name]
         set attr [dbGet ${rBlkPtr}.attr]
         set layer [dbGet ${rBlkPtr}.layer.name]
         foreach box [exl [dbGet ${rBlkPtr}.boxes]] {
      puts $f "createRouteBlk -box ${box} -layer ${layer} -name ${name}"
        close $f
    # Procedure to split the list
    proc exl {singleList} {
            set mylist {}
            foreach item $singleList {
                    set mylist [concat $mylist $item]
            return $mylist
