  3. No. of Single Cut Vias
  • Subscribers 92
  • Views 14477
archive over 13 years ago
Hi All
Can any one tell how can i find No. of single cut vias in the design.
  • wally1
    wally1 over 13 years ago
    You can use the following command to report the number of single cut and multi-cut vias in the design:
        pdi report_design -wire
    Brian
  • kazad
    kazad over 13 years ago
    Following procedure may help a bit - it reports only multi-cut via info. Single-cut via numbers can be extracted from there.
    Usage: reportMultiCutVia   ==> to get the mult-cut via%
    reportMultiCutVia -verbose  ==> to get detail via info
    proc reportMultiCutVia {args} {
        # Defaults
        set verboseMode "no"
        # Get verbose mode
        if {[regexp {\-verbose} $args]} {
            set verboseMode "yes"
        # Help
        set helpString "Usage : reportMultiCutVia -verbose -help"
        if {[regexp {\-help} $args]} {
            puts $helpString
            return 0
        # Main code
        # Get a list of all via cells
        set allUniqueViaCells [dbGet -u top.nets.vias.via.name *]
        # Get total via count
        set totViaCount [llength [dbGet top.nets.vias.via.name *]]
        # Get multi-cut via count
        set totMultiCutVia 0
        foreach viaCell $allUniqueViaCells {
            if {[llength [exl [dbGet [dbGetViaCellByName $viaCell].cutRects]]] > 1} {
                set viaCount [llength [dbGet top.nets.vias.via.name $viaCell]]
                set viaArray($viaCell) $viaCount
                set totMultiCutVia [expr $totMultiCutVia + $viaCount]
    #    foreach viaCell $allUniqueViaCells {
    #       set viaCellPtr [dbGetViaCellByName $viaCell]
    #       set cutinfo [dbInfoViaCellRegularCuts $viaCellPtr]
    #       set cutNumx [lindex $cutinfo 4]
    #       set cutNumy [lindex $cutinfo 5]
    #       if {$cutNumx > 1 || $cutNumy > 1} {
    #           lappend multiCutViaCells $viaCell
    #           set viaCount [llength [dbGet top.nets.vias.via.name $viaCell]]
    #           set viaArray($viaCell) $viaCount
    #           set totMultiCutVia [expr $totMultiCutVia + $viaCount]
        # Calculate multi-cut via%
        set multiCutVia_p [format %2.2f [expr ($totMultiCutVia*1.0/$totViaCount)*100]]
         # Report via info
        if {$verboseMode =="yes"} {
            Puts [genLine -width 15 -char "="]
            Puts [format "%-15s %15s" "Multi-cut via" "Count"]
            foreach viaCell [array names viaArray] {
                Puts [format "%-15s %15s" $viaCell $viaArray($viaCell)]
            Puts [genLine -width 15 -char "-"]
            Puts [format "%-15s %15s" "Total" $totMultiCutVia]
            Puts "\nTotal via count        : $totViaCount"
            Puts "Multi-cut via          : $multiCutVia_p%\n"
        } else {
            return "$multiCutVia_p%"
    proc genLine {args} {
        # Default
        set char "-"
        # Get width
        if {[regexp {\-width} $args]} {
            set width [lindex $args [expr [lsearch $args -width] + 1]]
        # Get char
        if {[regexp {\-char} $args]} {
            set char [lindex $args [expr [lsearch $args -char] + 1]]
        # Help
        set helpString "Usage : genLine -width <width> -char <character>"
        if {[regexp {\-help} $args] || $args == ""} {
            puts $helpString
            return 0
        # Main code
        for {set i 0} {$i <= $width} {incr i} {
            lappend print_list $char
        return "[join $print_list $char]"
  • kazad
    Forgot to include the following procedure:
    # Procedure to split the list
    proc exl {singleList} {
            set mylist {}
            foreach item $singleList {
                    set mylist [concat $mylist $item]
            return $mylist
