  3. Regarding Captables
  • Subscribers 92
  • Views 15030
Regarding Captables
Ganga111AtFPS
Ganga111AtFPS over 13 years ago
what is the mail difference between basic captables and extended captables?
I've opend captables file and I observed the basic tables and I understood.
But on what basis the Extended captables were generated?
  • wally1
    wally1 over 13 years ago
    Basic Capacitance Table - Provides a table of spacing versus capacitance information for each layer.
    Extended Capacitance Table - Provides encoded extraction patterns that are derived using a 3D field solver which provides much greater accuracy during detailed extraction.
    Brian
  • Ganga111AtFPS
    you based on what we'l get the extended captables?
    I mean to get capacitance values in 3D field we should have routed design but we have not yet routed our design, then how can we have extended caps in captables?
    I thought if we are working on a design which is having 1million gate count we might have used  the captables of already routed design which is having approximately 1million gate count.
    Please Explain in detail.
  • wally1
    Foundries will typically provide the cap table for the specific process. If you need to generate the captable, create an ICT file and use the generateCapTbl command.
