  3. How to report cells from window x1 y1 x2 y2
  • Subscribers 92
  • Views 16902
gpremala
gpremala over 13 years ago
Hi All,
I want write a script to get below things with dbGet commands.
How do I give coordinates to dbGet command for the following.
1.
I want to get cell count from window x1 y1 x2 y2.
it should report count for sequential, inverter, buffer, other combinational cells with cell name.
2.
it should report pattern (*AND*) cell count in particular area by giving coordinates.
Gopi Premala
  • wally1
    wally1 over 13 years ago
    Hi Gopi,
    I think the command "dbQuery -area {x1 y1 x2 y2} -objType inst" will help you here. It will return pointers to the instances in the specified area. You can then parse the list to get the cell types, etc.
    Brian
  • BobD
    BobD over 13 years ago
    I was going to suggest dbQuery as well. For the breakdown by type, have a look at "userReportArea.tcl" in the gifts dir. It might provide a useful example for how to summarize cells by type:
    Type            Count  Area(u^2)
    Standard Cell:   5906  133841.03
      Buffers:        193
      Inverters:      478
      Sequentials:    543
      Comb:          4692
    Block:              4  366346.56
    BlackBox:           0       0.00
    IO:                71  850700.00
    Area IO:            0       0.00
    Sum:             5981 1350887.59
    Total:           5981 1350887.59
    Die Density = (Standard Cell + Block + Black Box + IO Cell + Area IO Cell) / Die Area
    Die Density = 133841.0304 + 366346.562025 + 0 + 850700.0 + 0 / 1558322.095
    Die Density = 1350887.59243 / 1558322.095
    Die Density = 86.69%
    INFO: Die area was found to be rectangular:
      Die Area = (Width * Height)
      Die Area = (1255.375 * 1241.32)
      Die Area = 1558322.095 u^2
    Hope this helps,
    Bob
  • gpremala
    Thank you Brian, for your quick reply.
    Here I want to fileter out cell (*AND*).
    How do I do with db command.
    Gopi Premala
  • wally1
    Hi Gopi, Try the following:
         set instPtrs [dbQuery -area {x1 y1 x2 y2}
         set cellPtrs [dbGet -v -p $instPtrs.cell.name *AND*]
    The -v says omit objects that don't match *AND*. Use -p2 to return the inst pointers instead of the cell pointers.
    Brian
  • gpremala
    Hi Brian,
    Thank you for your help.
    Where can i find the documents for db commands and its info.
     Gopi Premala
  • BobD
    Search for "dbGet" on support.cadence.com and the following is under "New or Changed Features":
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=wp;q=ProductInformation/Digital_IC_Design/ApplicationPackages/download/EDI11_DBTCL_slides.pdf
    It covers dbGet, dbQuery and other related db access commands.
    Hope this helps,
    Bob
