  3. FoundationFlow - what about floorplanning?
  • Subscribers 92
  • Views 735
ErezBS
ErezBS over 13 years ago
Hi i have looked at the foundation flow scripts.
i didnt found anything regarding floorplanning, should  this step exists? or this flow starts from placement step?
Thanks.
  • wally1
    wally1 over 13 years ago
    Floorplanning is typically an interactive step but if you've scripted your floorplan creation you can specify the script in the setup.tcl file using:
        set vars(fp_tcl_file) fileName
    The Foundation Flow will then source the script during the init step. Alternatively, if you have it defined in a procedure you can set the variable:
        set vars(fp_tcl_proc) procName
    Lastly, there are prototyping Foundation Flows you can utilize to do your floorplanning. See the Rapid Adoption Kits available here:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=wp;q=ProductInformation/Digital_IC_Design/ApplicationPackages/ICD_RAK_Home.htm
    Hope this helps,
    Brian
