  3. can not add filler between some standard cell
  • Subscribers 92
  • Views 14465
quiet
quiet over 13 years ago
When I try to add fillers in my design, there are some gaps between standard cells that can not add fillers into.
What may be the problems?
Thanks.
  • Scrivner
    Scrivner over 13 years ago
    If you routed before placing fill cells, there may be routing in the gaps that prevent the fillers from being placed.
  • quiet
    Yes, but if I add fillers before routing, won't it prevent the optimization for the timing?
  • Scrivner
    The normal flow is to perform timing optimization, place fillers and then route. If there are timing violations post-route, you remove the fillers, perform timing-opt again, place fillers again, and then do an eco-route. If you use the command setFillerMode to define the fill cells and some other filler behavior, the removal and replacement of fillers is done automatically when running optDesign -postRoute.
