  3. Connect macro power to top level
  • Subscribers 92
  • Views 13847
ErezBS
ErezBS over 13 years ago
I have read alot about this issue (in this forum), but still don't having some problems.
i have power strips + power ring  in my block, and i use lefOut -stipePin in my block to generate the lef file for top level.
i can see in the lef file the power & ground  port  (also see "use power" & "use ground", and a list of "RECT" in top layer).
the problem is - i can't connect my top power strips to my macro block.
i use the "globallnetconnect"  in my top level & in block level with the same names.
the thing is when openning my top level and reading the lef, i can see the block pins but not the VDD & VSS ones.
any idea?
thanks!!
  • Kari
    Kari over 12 years ago
    globalNetConnect specifies what pins are connected to which global nets, but it does not actually draw the connections. you need to use sroute for that. Here's a sample lefOut command which might work better for you (edit to reflect the layers you want):
    lefOut block}.lef -noCutObs -stripePin -pgPinLayers 1 2 3 4 5 6 7
