  3. N/A for all timing paths
  • Subscribers 92
  • Views 1668
ErezBS
ErezBS over 12 years ago
I am running Encounter with ILM blocks.
i have succesfully created the ILM and imported them to my top level.
However, after placement step ends, and i run timeDesign, i am getting "N/A" for all values in timeDesign summary table.
the sdc file is well defined and succesfully loaded at the beggining.
only after i run "flattenIlm" and resource the sdc file, i can see values in timeDesign table.
Help anyone??
Thanks!
  • wally1
    wally1 over 12 years ago
    Make sure you specify the SDCs using create_constraint_mode/update_constraint_mode -ilm_sdc_files. The SDCs specified with the -ilm_sdc_files option are used when the SDCs are flattened. The -sdc_files is used when the blocks are represented with .libs instead of ILMs.
    Brian
  • ErezBS
    Hi, thanks for your answer.
    A few more questions:
    I should define the constraint mode even if i dont work with mcmm?
    the sdc for ilms is the sdc created with the ilm?
    Thanks!
  • ErezBS
    BTW. what should i define in order to work with ILM and non MCMM design?
    thanks.
  • wally1
    To specify the ILM SDCs in a non-MMMC flow list them in the config file with the variable "set rda_Input(ui_timingcon_file,full)". The file specified is used when the ILMs are flattened. The related variable "set rda_Input(ui_timingcon_file)" is used when the blocks are represented with .libs.
    - Brian
  • ErezBS
    thanks.
