  3. Does encounter optmizes ideal net when optdesign command...
  • Subscribers 92
  • Views 13726
Does encounter optmizes ideal net when optdesign command is given.
gops
gops over 12 years ago
In new version of encounter there is no provision to give exclude nets while loading design. But I have set_ideal_net in my SDC, a reset net which I want to do buffer tree synthesis. But while doing optdesign after placedesign, I found encounter buffering those ideal_nets. How can i solve this issue.
  • Kari
    Kari over 12 years ago
    if you don't want optDesign to buffer that net, make the net set_dont_touch.
    set_dont_touchobject_list[true | false]
    Prevents the specified object from being modified during optimization.
    When you specify a net, all the connecting instances are affected by the set_dont_touch command.
