  3. How dump lvs netlist from encounter ?
  • Subscribers 93
  • Views 14844
pandamaneni
pandamaneni over 12 years ago
 Hi Guys,
After merging the gds in encounter I dumped netlist only
I tried below commands
saveNetlist filename_v2lvs.v.gz
saveNetlist -includePGporInformation filename_lvs.v.gz
Right Now I am using encounter 11.11v
whenever I ran calibrelvs ports/nets are mismatched in layout.spi ,instances are passed
How to debug those ports/nets mismatched  ?
  • scudex
    scudex over 12 years ago
     normally  I use
     saveNetlist -phys blablubb.v
     It should work.
    scudex
  • vimalraj205
    vimalraj205 over 12 years ago
     hai friend
     after saving the final netlist from encounter
    you need to change the netlist into spice netlist using the tool v2lvs
      v2lvs -v <lay.v> -s <spicelibrary> -l <verilog_lib> -o outpu_spice
