  3. Via Placement issue.
  • Subscribers 92
  • Views 13582
Leader
Leader over 12 years ago
Hi every one,
I'm Lakshmi Prashanth, and  i'm new to this encounter tool, I've got a problem., initially when i was moving the PG net over the Macros, tool was automatically placing the via's, But suddenly yesterday, some via's are deleted automatically, I don't know how, and If try to move it again, it is placing only on few location, and some time it is place only via45 and via56 without via67 for met4 to met7 connection. Is there any snap options to switch on,
I've switched on the following snaps. for addvia menu snap is on,
shift+A --> E --> snap --> regular, via interaction, add to pin, special options are on.
Please provide a solution
  • Kari
    Kari over 12 years ago
    make sure you click the options tab on the edit route form, and select the layers you want vias between.
