  3. Question on #LM Placement using EDI 10.1 USR3
  • Subscribers 92
  • Views 13297
JAUB
JAUB over 12 years ago
Running placement on a small digital block (about 37K instances -- part of a mixed signal design) using a 3LM technology that often has issues with placement densities in the 60percent rang, i.e., 55% placement density can be seen as a high density design when routing.
Have seen good results using  "setPlaceMode -threeLayerMode true" ; however,  it does not always give me optimal results.
Would setting "setPlaceMode -modulePlan false"  be a useful option on running on this type of technology? When I was at Cadence, I recall being told to set that variable to "true" to use the new placement engine (new at that time) but was never given a reason to turn off modulePlan.
Someone recommended to another designer  to run 3LM placement with modulePlan turned off. Does it ever make sense to do that ?
The floorplan contains no fences, regions, guides, or  density screens, which "modulePlan false" does not support. Have experiemented with these various floorplan constraints, but often they are counterproductive on small blocks.
Have implemented quite a few 3LM designs in this technology so I am running the typical 3LM high density settings  (in various combnations): congEffort high, doCongOptt true, -clkGateAware true, threeLayerMode, scan reordering, etc.  Ran tricks like congRepair which has been useful for quite a few year now.
Just not sure if turning off modulePlan is worth the effort or time. Any recommendations on when to turn it off ?
Thank You and Regards,
 Jeff Aubert
