  3. report all paths for same start point and end point
  • Subscribers 93
  • Views 18460
ajay01
ajay01 over 12 years ago
 hi all,
when i am using report_timing for start point and end point...
it will give me worst slack path for start point and endpoint.....
but i want to report all path for one start point and one end point....
how can i do that?????
  • Arslan
    Arslan over 12 years ago
     Hi, i think using -max_path with report_timing will give you other paths also.
    e.g., report_timing -from cout_reg[0]/Q -to cout_reg[0]/D -max_paths 15
    just give max_paths parameter a value approximately large enough to cover all the paths.
    -Arslan
  • Arslan
     Also u can view these paths in gui by first typing following command
    report_timing -machine_readable -from cout_reg[0]/Q -to cout_reg[0]/D -max_paths 15 > timing_report
    and then from gui goto timing -> debug timing and unselect generate and give generated report path.
    -Arslan
  • ajay01
    its working fine.... Thanks arsln
    Ajay01
