  3. not able to add repeater
  • Subscribers 92
  • Views 15584
archive over 12 years ago
 Hi All ,
when i am adding a eco repeater for one instance term its showing the following error , how can i rectify this.
 **ERROR: (ENCOPT-6078):    Cannot insert buffer/inverter as it is not possible to distribute the spef for the terms specified.
  • wally1
    wally1 over 12 years ago
    This may be due to the location you are inserting the buffer on shares a node in the SPEF with another sink so it cannot be separated. One solution is to add additional sinks for this net to the list of terminals. Also, try using the latest code as some updates have been made.
    Brian
  • DESIGNARCHITEC
    DESIGNARCHITEC over 10 years ago
    Hello Brian,
    Could you explain it more briefly. I mean in terminal
  • wally1
    wally1 over 10 years ago
    If it fails with this message when specifying a single sink:
    add_repeater -term sink1 ...
    Then try adding additional fanouts that this net drives:
    add_repeater -term {sink1 sink2 ...} ...
    Brian
  • DESIGNARCHITEC
    Hey, could you tell me how to convert the script generated in Prime Time to Encounter format, so that we can verify the violations in encounter whether thet were fixed or not.
