  3. Prevent OptDesign in between paths
  • Subscribers 94
  • Views 15608
dinac123
dinac123 over 12 years ago
I am trying to prevent Optimization between a path.
set_dont_touch, works only for the complete net, but not between a begin pin to a End Pin.
Is there any other option to achieve this type ofcontraints?
Thank You
  • ajay01
    ajay01 over 12 years ago
     Hi dinac123,
    use below command:
    set_false_path -from beginpin -to endpin
  • dinac123
    That will not work. set_false_path is only to ignore paths for the timing engine and would still add optimization buffer in the path.
    I think there is no option availabe to do this. For now only trick, I found is to add Fence. [ running with setOptMode -honorFence true , prevent
    addtion of buffer under this region, and hence force encounter to buffer after/outer ]
  • ajay01
    fence will work for a module or group not for path..........
  • skmhs PD
    skmhs PD over 12 years ago
    you'd need to develop a Tcl script to obtain all net names along the path then set_dont_touch.
  • dinac123
    yes, set_dont_touch would work for the nets.
    In my case, for example U1/a is connect with N1 to U2/a, U3/a,U4/a.
    I want no optimization buffers only for the path U1/a to U3/a
  • skmhs PD
    That doesn't quite make sense. Are you talking about setup or hold opt? And what's the reason behind this requirement?
