  3. Difference between AntennaAreaRatio and AntennaDiffArea...
  • Subscribers 91
  • Views 14033
Difference between AntennaAreaRatio and AntennaDiffAreaRatio
archive over 12 years ago
 Hi All ,
What is the difference between  AntennaAreaRatio and AntennaDiffAreaRatio ?
Thanks in advance.
  • wally1
    wally1 over 12 years ago
    If there is a connection between the input pin and diffusion through the current layer being evaluated or below, then AntennaDiffAreaRatio is used. Otherwise, AntennaAreaRatio is used. AntennaDiffAreaRatio is always larger because the diffusion provides a discharge path.
    A good chapter on antenna calculations can be found here:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=lefdefref/lefdefref5.8/PAE.html
    - Brian
