  3. dumping power pins and their connectivity
  • Subscribers 92
  • Views 14209
KVBABU
KVBABU over 12 years ago
 Hi All,
Iam working on place route for  mixed signal design and i have a verilog netlist with PG pin connectivity defined for analog macros and for the digital cells , iam using global net command.
Just i wanted to dumping out the PG pin name of analog macro and its associated net  using the EDSXL (encounter ) prompt. How is it possible? Are there any scripts or dbCommands ???
Please help me in this regard.
K.VISWANADH BABU
  • MOHAN KUMAR CH
    MOHAN KUMAR CH over 12 years ago
     refer to one of the COS solutation of the similer one , which you need to costamise for your need
    http://support.cadence.com/wps/myportal/cos/COSHome/viewsolution/!ut/p/c5/dY1bcoIwAEXXwgKchJRH-AyvEJgCAyLCj5MBsRhJqkVsXb24gJ77eebOAS1YJ_kynvg8KskvYA9a66Aj6umJAZ3MSzFk2EqTYhfAFVC_H9YB_gOBoAGt_fYI6Rg6NNy6kHkJi7H9gWBigZ1Ut2ktbcE-6pTpK3IKiE_iP8gei_I99JlHXVeOnFFjwBzhibjFPbbHesjMrzrDgfRtwedZOPT3LK6sFlku42Zw3WtbllQdRUVvd2PZLMrusax_Fjmq5nkJHqoQVZhVoerz3iSaBtJITUfwLeQzxER7AQyWa4g!/dl3/d3/L2dBISEvZ0FBIS9nQSEh/
  • MOHAN KUMAR CH
    even you can get the same by Selecting such instance and use the below dbGet cmd to print the Power and Ground details dump
     dbget -p selected.pgCellTerms.name
