  3. Experiensing odd behaviour with encounter
  • Subscribers 93
  • Views 14681
Thodoros
Thodoros over 12 years ago
I am trying to implemen t a divider using macro cells with  encounter. The LEF of a macro cell is attached.
The macro cell consists of two standard cell rows sharing the gnd! in the middle. So the macro cell starts with power (vdd!) on top,
has ground (gnd!) in middle and ends with power (vdd!) at the bottom.
With encounter (versions mainly 9.1 and also 10.1) I commit floorplan and I do specialRoute to get gnd! and vdd! rails. Than I perform a standard cell placement.
My problem is  that the cell is auto placed at a gnd! - vdd! - gnd! combination whereas it uses vdd! - gnd! - vdd! combination.
I try to move slitly the macro (i.e to the right) and when I release it, it is auto moved to the row below as to use the proper vdd! - gnd! combination. So I do not think that it is a pin problem.
  The problem does not occuse when the macro has gnd! at the bottom (and not in the middle).
 Why is encounter showing me this behaviour?
Thanks for your help (to which I am in desperate of),
My appologies for consuming your time,
Thodoros
  • aCASCell.lef.txt
  • wally1
    wally1 over 12 years ago
    Hello Thodoros,
    If this is a double-height cell then you should have double-height rows defined in your floorplan which align properly to the single-height rows so the power rails align properly. For example, typically you will have two site definitions:
    SITE CORE
      SIZE 2.8 BY 2.52 ;
      CLASS CORE ;
      SYMMETRY Y ;
    END CORE
    SITE CORE_2X
      SIZE 2.8 BY 5.04 ;
      CLASS CORE ;
      SYMMETRY Y ;
    END CORE
    Specify Floorplan will then automatically create the single and double-height rows if instances in the netlist use these sites.
    Brian
  • Thodoros
     Dear Wally,
    Thanks for your help. It was exactly what I needed to do.
    Thanks!!
  • jinghuayang
    jinghuayang over 11 years ago
    I have a similar problem except that my cell has gnd-vdd-gnd power lines and encounter is placing them in vdd-gnd-vdd configuration. I have specified the double row site as stated. Is there a way to fix this?
  • Kari
    Kari over 11 years ago
    you might have to manually specify the start of the double-height rows. sounds like they are off by one single-row height.
