  3. Ports mismatch
  • Subscribers 92
  • Views 14787
Ports mismatch
Ridus
Ridus over 12 years ago
Hi ,
I am running LVS, I have assigned ports in the desing but still in LVS report layout has 0 ports. I am working on Encounter10.13
 dv_obj_count -transformed_nets {132639 59910} -transformed_inst {180591 116168} -transformed_port {0 423}
dv_discrep 1 {Incorrect Nets}
I am using the below command to save the netlist.
saveNetlist design.v -excludeLeafCell -includePowerGround -excludeLogicalCell {FILL16BWP FILL8BWP FILL4BWP FILL2BWP FILL1BWP} -includePhysicalCell {GDCAP4BWP GDCAP2BWP GDCAP3BWP GDCAP4BWPLVT GDCAP10BWP GDCAP3BWPLVT GFILL3BWP GFILL2BWP GFILL4BWP GFILL3BWPLVT GFILL2BWPLVT GFILL4BWPLVT GFILL10BWP} -replaceTieConnection
Kindly help me on this.
Thank you.
Regards..
  • Kari
    Kari over 12 years ago
    if you think the problem is in the layout, it has nothing to do with your netlist. however, typically you want a physical verilog for LVS (saveNetlist -phys). Do you have an edtext file for your top-level ports that you include in the LVS run?
