  3. How to optimize level shifter and isolation instances marked...
  • Subscribers 93
  • Views 15105
How to optimize level shifter and isolation instances marked dont touch in Encounter
fieldy
fieldy over 12 years ago
Hi All,
I am implementing a Low-power design with Power switches and Isolation cells. I have a CPF file that I commit and I can see that isolation cells and level shifters are inserted into the design correctly as I intended.
However, whenever I run optDesign, whether it be preCTS, postCTS or postRoute, Encounter seem to mark level shifters and isolation instances as don't touch instances and does not optimize them. As a result, the drive strength of the isolation instances are too small. I know that Encounter doesn't optimize clock nets but there is a ckECO option to take care of clock optimization. Is there a way to make Encounter optimize the level shifter and isolation instances and/or remove the dont touch marking on these instances?
 Below are the messages I get in the log file when I run optDesign :
*info: Marking 12 level shifter instances dont touch
*info: Marking 64 isolation instances dont touch
I've tried to use set_dont_touch and set_interactive_constraint_mode options to override this but haven't succeeded so far. Has anybody gotten the same problem and does anybody know how to solve this?
Saekyu
  • fitz
    fitz over 12 years ago
    setOptMode  -resizeShifterAndIsoInsts {true | false}
    Controls whether timing optimization resizes shifters and isolation instances. In default mode (false), shifters and isolations are considered "don't-touch" instances and are not changed during timing optimization.
    When this parameter is set to true, the shifters and isolation cells are resized for timing optimization by using optDesign.
    Note: When this parameter is set to true, all the shifters and isolation cells can be resized even if they are marked as dont_touch.
    Default: false
  • fieldy
    Thanks so much! This was exactly what I was looking for!
