  3. report_timing -max_paths regarding
  • Subscribers 93
  • Views 4115
vimalraj205
vimalraj205 over 12 years ago
 Hai friends
 I am confused why this command
report_timing -max_paths 10 is reporting only 5 different paths each path repeated two times
  Anybody has already known this reason
 please help me.....
Vimal
  • wally1
    wally1 over 12 years ago
    You are likely seeing a rising and falling path between each begin/end point or the path is going through different logicc. If you want each end point to be unique use -max_points.
    - Brian
  • vimalraj205
    Thank you Brian for  your valuable suggestion...
  • sruthikesh
    sruthikesh over 12 years ago
    Is this a newly added command because I'm not able to use this command.
    Error   : A command argument did not match any of the acceptable command options. [TUI-64] [report timing]
            : The argument in question is '-max_paths'.
            : Check the command usage and correct the input to the command.
    command used is : report timing -max_paths 5 > timing.rpt
    Is there something to be added to the script to enable max_paths command. Does this command print only 1 path for a logic.
    Thanks and regards
    Sruthikesh
  • grasshopper
    grasshopper over 12 years ago
    Hi Sruthikesh,
     Looks from your error message you are using RC and not EDI/ETS/Tempus. The suported options there are indeed not identical
    gh-
  • sruthikesh
    Hi gh
    yes it is RC and is there a similar option in RC to report only 1 path for a start and endpoint.
