  3. Encounter to Virtuoso
  • Subscribers 93
  • Views 14541
MarcoUdS
MarcoUdS over 12 years ago
 Hi all,
 It is my first time on this forum so please may apologize  my lack of knowledge in some matter.
I'll put my problem in context:
We are designing a mixed-signal project in technology tsmc65nm. I work on the digital side and I have problems to port my design in virtuoso. Right now, I have generate a digital circuit for my college in order to integrate it in his analog design in Virtuoso.
I succeed in creating the «gds» file and somehow importing it to Virtuoso but once I open it, the layer doesn't match and I have a bunch of DRC violations.
Then  I create a library and I imported the «lef» file of my standard cell (which also include layer etc) and I attach it to the technology file corresponding (*.tf). Then I created a «.def» file and I import it to this new library. In this way, I was able to see the good layer but no layout view of the standard. I tried some trick to get them but with no success...
I saw that it would be possible to translate «lef» file to oa library and then the transfert between Encounter and Virtuoso is much easier. But I tried but I think that I'm mixed up with all the required file.
 I can tell you the type of file that I have:
.lef => with the layer, standard cell etc
.map
.tf
If someone know a way I could solve my problem either by creating the OA lib of telling me the way to be able to transfert my design to Virtuoso and be able to see it with the standard cell layout and then pass the DRC, I would be more than happy.
If I misunderstanding some matter, feel free to educate me!
 Thank for your support
  • selvam27
    selvam27 over 12 years ago
    Hai,
    You can convert oa from lef using following command.
    1) lef2oa -lef lef_file_name -lib output_library
    But std cells in the output library only in abstract view. (you can see only metals in abstract view).
    Also,
    2) strm2oa -gds input_gds_file_name -lib output_library -techLib tech_file_name
    to generate oa from gds. The outputs cells are in layout view.
     I think these commands help you.
    selva
