  3. Printing common elements between 2 collections
  • Subscribers 92
  • Views 15530
abhishektheone
abhishektheone over 11 years ago
 Is there a quick way to print all the common elements between 2 collections. Right now I am doing to usual loop method of comparison. Please let me know if there is an easier/faster way.
  • BobD
    BobD over 11 years ago
    Not that I know of, though I've had interest in doing the same for TCL lists.
    There's a script called "userListUtilities.tcl" in the gifts dir that might be useful. It contains a proc called "userIntersectLists" that takes 2 lists and finds the common elements. If you converted the collections to lists you could use it (or perhaps modify it for your use?).
    For example - say I have a design with 2 instance: i0 and i1
    encounter 2> set a [get_cells i*]
    0x25
    encounter 8> set b [get_cells i1]
    0x27
    Collection a contains i0 and i1, and collection "b" contains just i1:
    encounter 10> get_object_name $a
    i0 i1
    encounter 11> get_object_name $b
    i1
    Then you could use this proc to interest them (which is probably what you've already written but perhaps a little more fast-running):
    proc userIntersectLists args {
      set res {}
      foreach element [lindex $args 0] {
        set found 1
        foreach list [lrange $args 1 end] {
          if {[lsearch -exact $list $element] < 0} {
           set found 0; break
      if {$found} {lappend res $element}
      set res
    encounter 9> userIntersectLists [get_object_name $a] [get_object_name $b]
    i1
    We've discussed providing more list manipulation in the tool and this is a good example of where that would be helpful. We have pretty cool capabilities for shape manipulation with dbShape but basic TCL lists are, perhaps ironically, harder to work with at the moment.
    Hope this helps,
    Bob
  • abhishektheone
    Thanks Bob, This method is definitely fast. Regards, Abhishek
