  3. Need to trace a path from a port to all the memory_instance...
  • Subscribers 92
  • Views 13825
Need to trace a path from a port to all the memory_instance it is connected
Anuragjn
Anuragjn over 11 years ago
HI All,
Have a query on First Encounter tool.
I have a port(abc) which is connected to all the memory_pin(abc) in the design through aob's
I need to trace the connectivity and dump_out the complete path through that port
Second is there a way to hightlight in layout like how they are placed or view in schematic the entire path from the port to all the memories.
 Can someone please help out on this like how to go on wiht or if someone could provide with a script.Need urgent support on this.
Apprecaite your help
-Thanks
  • wally1
    wally1 over 11 years ago
    I pulled the following code from Article 20093020 on http://support.cadence.com. It uses all_fanout to report the pins in the path then uses selectPin to select the nets. Hope this helps:
    deselectAll
    all_fanout -from <pin/port name>  -trace_through all > pin_list_file.txt
    set pinfile [open "pin_list_file.txt" r ]
    set file_data [read $pinfile ]
    close $pinfile
    foreach pin  $file_data {
       selectPin $pin
