  3. [Q] Edit Rules for SoC Encounter Stream-out Layer Map
  • Subscribers 92
  • Views 14154
M Refaat
M Refaat over 11 years ago
Hi all,
I need some details about how to modify the stream out layer map file generated by Encounter according to technology mapping file. (i.e. which layer stream number/datatype to use, which layer  purpose to be modified, ...). I am using TSMC 65nm GP.
Thanks in advance,
  • Kari
    Kari over 11 years ago
    you should have either a design rule manual or a stream layer map for your process. you can use either one to build the encounter stream map file.
