  3. Active analysis view
  • Subscribers 92
  • Views 16308
iullah
iullah over 11 years ago
Hello!
I am new to Cadence EDI. I am currently using Encounter 13.2
How can I find the current "active analysis view"? There is a command "all_analysis_view", but it gives all the views defined in viewDefinitions file not the active ones.
Thank you in advance.
Imdad
  • kazad
    kazad over 11 years ago
     Hi Imdad
     You can try 'report_analysis_views -type active'.
    Khandaker
  • iullah
    Hi Mr. Khandaker
    Thanks for quick reply.
    It gives detailed view. I need only the name i. e. func_LT_rcbest_0_hold.
    I can grep for "Analysis View" & it works. It will be better if it gives analysis view name directly.
    Imdad
  • kazad
    Hi Imdad
    To get all active setup/hold analysis views, you can try : all_setup_analysis_views/all_hold_analysis_views
    Khandaker
