  3. Moving two instances together during placement
  • Subscribers 93
  • Views 16697
zamzam
zamzam over 11 years ago
I have a placement question.
1) Is there a command/constraint that can be set for moving an instance and a desired unconnected spare cell together during placement?
2) Is there a command/constraint that can be set for moving an instance and a desired unconnected spare module (containing multiple spare cells) together during placement?
I have a workaround where I add some padding to the first instance and then move the desired spare modules/cells in that padding region after the initial placement. But it would make my life  alot easier if I can somehow use some constraints that allow them to move together as the design is placed.
Zaman.
  • fitz
    fitz over 11 years ago
    Zaman
    If the cells are unconnected there is little incentive for placeDesign to keep the cells together.
    Defining custom groups and classifying them as soft guides may be your best semi automated placement option.
    ( as long as you do not require strict adjacent placement and “nearby” is sufficient )
    createInstGroup
    addInstToInstGroup
    createSoftGuide
    setPlaceMode –softGuideStrength high
    Shawn
  • zamzam
    zamzam over 10 years ago
    Hi Shawn, Thank you for the tips. Defining and placing them in groups does work for me. Thanks,Zaman.
  • fitz
    fitz over 10 years ago
    Structured Data Path placement is the next level, some benefits , some downsides.
    I have only used groupFlopToGate and/or sdp placement for clock gated register arrays, but it should work equally well for relative register + combinational logic.
    The upside is you are guaranteed the exact relative placement you have predefined.
    Manual definition of the sdp groupings are a bit tedious until you get the hang of row, column, space .
    ( incredibly tedious if synthesis keeps changing the instance names of the related combinational logic@#$% )
    The downside seems to be the placed structured data path array cannot be optimally moved during optDesign , the defined sdp arrays are tagged “fixed” during initial placeDesign.
    To avoid this issue I tried ………..
    placeDesign -groupFlopToGate > optDesign > define SDP > placeDesign –incremental > optDesign …..
    Shawn
  • zamzam
    Hi Shawn, I had tried grouping with an absolute bounding box (createInstGroup <groupName> -region llx lly urx ury) and it worked. However, when I use softGuide as per your suggestions above, it seems like the grouping doesn't work. The spare cells are placed all over the place. Are there any other parameters that need to be set for softGuide to work? I tried it for both before and after standard cell placement and none of them are working for me.
  • fitz
    ZamZam:
    Input tie-hi / tie-lo connected spare cells are by definition "floating", Placement efficiency demands spare cells migrate to the least offensive routing location, and ultimately the most useless ECO corner locations. If you are truly anticipating an ECO connect your first guesstimate spare inputs to the  real logic. that way it is already local and the extra ip pin cap is just noise.
    setPlaceMode -moduleAwareSpare might work with user created groups
    OR let the far more useful  placeSpareModule  evenly distribute spares.
    OR better still backfill with programmable gate-array-ish  DeCap cells.
    Shawn; Spare cells? Spare cells ? Who needs stinking Spare cells : )
