  3. Find net name in Encounter with dbGeet
  • Subscribers 92
  • Views 16357
gdellaca
gdellaca over 10 years ago
HI,
Iim trying to use dbGet command to find and select the net connected to one terminal of an instance, for example the net connected to port A of instance U1 ( U1/A ). Please anybody knows how tu use dbGet for this?
  • wally1
    wally1 over 10 years ago
    Here you go:
    set netName [dbGet [dbGet top.insts.instTerms.name U1/A -p].net.name]
    selectNet $netName
    Brain
  • gdellaca
    thank you Brian, but there must be something wrong because I get 0x0 after the first command
  • wally1
    0x0 is the null pointer. You can unroll the commands to debug:
    # Get the termPtr first. If this returns 0x0 then U1/A does not exist in the database:
    set termPtr [dbGet top.insts.instTerms.name U1/A -p]
    # Get net name connected to $termPtr:
    set netName [dbGet $termPtr.net.name]
    # Select the net:
    selectNet $netName
    - Brian
  • gdellaca
    Thank you, I had to go down into the hierarchy to find the right name (it was U1/A_reg/Q), even if the instance terminal is U1/A
