  3. characterizing pex netlist using elc
  • Subscribers 92
  • Views 13291
KALYANICH
KALYANICH over 10 years ago
When I'm running ELC to characterize pex netlist of my cells, i'm facing the following problem.
[WARNING(db_spice)]No spice simulation to do, please check the cell/process list for any error
But when i use the netlist from schematic simulations are running without any problem.
Following are the steps followed:
db_open AOI21X1
db_install -model ts18sl_scl.lib -subckt AOI21X1.pex.netlist
set_var SG_SPICE_SUPPLY1_NAMES "vdd vdd2"
set_var SG_SPICE_SUPPLY0_NAMES "gnd gnd2"
db_gsim
db_setup -s setup.ss
db_spice -s spectre -keep_log
db_output -r AOI21X1.rep -alf AOI21X1.alf -p typical
db_close
exit
Please help me if i'm missing anything in the process from pex to elc simulation.
Thanks.
