  3. High Fanout nets synthesis encounter
  • Subscribers 93
  • Views 15737
kenambo
kenambo over 9 years ago
Hi All
              I got the high fan out nets using dbGet command into a list. Then I used bufferTreeSynthesis command and got an error.
The error says...  the net a/b/c/d/n_1 has no driver .. and the buffer tree synthesis aborted.
Actually the net it shows is the  input of a macro which i have included in the design.
So what I have to do to get successful buffer tree synthesis. I am struck here.
Added to the above, while i m doing buffer tree synthesis for another design I got two nets that are VDD and VSS also has no driver and the synthesis aborts.
How to Declare these nets as Ideal nets and avoid being called as High fanout nets,.. any suggestions please?
thanks,
  • kviswanath
    kviswanath over 9 years ago
    set_driving _cell command may help including it in sdc.
  • Kari
    Kari over 9 years ago
    you need to figure out why that net doesn't seem to have a driver. sounds like something might be wrong with the netlist. as for VDD/VSS, BTS should not be trying to buffer those if you didn't list them in the -nets option.
  • kenambo
    Hi Kari..
              I found out the problem. The power nets haven't routed properly and They haven't declared as special nets too. Now It has been figured out.
    Thanks.
