  3. How to prohibit non-preferred routing?
  • Subscribers 93
  • Views 15066
scudex
scudex over 9 years ago
I have design in which I need to garantee that routing results are done on preferred routing direction only. Exactly as specified in LEF: Metal1 H, Metal2 V, Metal 3 H a.s.o.
But I don't see any option how in setAttribute/setNanoRouteMode how to force EDI to do so? For routing, I simply use routeDesign -globalDetail without -wire optimiazation flag.
Has anyone an idea how to control this?
Thanks, and best,
scudex
  • kazad
    kazad over 9 years ago
    Hi
    Can you try the following attribute before the global detail route?
    setAttribute -net * -preferred_routing_layer_effort high
    After the detail route, try 'pdi report_design -wrong_way_wire' to check non-preferred routing statistics.
    Khandaker
  • scudex
    Hi Khandaker,
    many thanks first. In the meantime I already specified this option. I also used  deleteTrack  for the non-preferred directions but still I get not really good results. I also tried to use wroute, but without success.
    s-
