  3. power pins of stdcells
  • Subscribers 93
  • Views 14308
chitlesh
chitlesh over 9 years ago
Hi there,
Is there a way to get the power pin names of a particular placed stdcell within EDI?
  • kazad
    kazad over 9 years ago
    Hi
    You can try the following procedure to get the power/ground name(s) of a given instance.
    Usage : findPGTerms -inst <instance_name> -termType <power | ground>
    # Procedure to find a list of Power/Ground pins of all cells in the design
    # Usage : findPGTerms -inst <instance_name> -termType <power | ground>
    proc findPGTerms {args} {
    # Get instance name
    if {[regexp {\-inst} $args]} {
    set instName [lindex $args [expr [lsearch $args -inst] + 1]]
    # Get term type
    if {[regexp {\-termType} $args]} {
    set termType [lindex $args [expr [lsearch $args -termType] + 1]]
    # Help
    set helpString "Usage : findPGTerms \
    \-inst <instance_name> \
    \-termType <power | ground> \
    \-help"
    if {[regexp {\-help} $args] || $args == ""} {
    puts $helpString
    return 0
    # Main code
    # Get inst/cell pointer
    if {[dbGet top.insts.name $instName] == "0x0"} {
    puts "\nERROR: Instance $instName not found!\n"
    return 0
    } else {
    set instPtr [dbGetInstByName $instName]
    set cellPtr [dbInstCell $instPtr]
    set allPGTerms {}
    dbForAllCellPGFTerm $cellPtr termPtr {
    if {${termType} == "power"} {
    if {[dbFTermType $termPtr] == "dbcPowerTerm"} {
    set powerTerm [dbFTermName $termPtr]
    lappend allPGTerms $powerTerm
    } elseif {${termType} == "ground"} {
    if {[dbFTermType $termPtr] == "dbcGroundTerm"} {
    set groundTerm [dbFTermName $termPtr]
    lappend allPGTerms $groundTerm
    set PGTerms [lsort -unique $allPGTerms]
    return $PGTerms
  • chitlesh
    this worked like a charm.
    thanks
  • kazad
    Hi
    I updated the procedure to get the associated net connectivity, use '-net' option. If a PG term is not hooked up with global net connection, it'll report '0x0'.
    Here is some usage example:
    Pin only:
    encounter> findPGTerms -inst /A/B/C -termType power
    VCC VDD VPP
    Pin and net:
    encounter> findPGTerms -inst /A/B/C -termType power -net
    {VCC vaa2v8_otpm} {VDD vdd_otpm} {VPP VPP_0}
    # Usage : findPGTerms -inst <instance_name> -termType <power | ground> -net
    # Get instance name
    # Get term type
    # Help
    \net \
    \-help"
    puts $helpString
    return 0
    # Main code
    return 0
    } else {
    foreach pgTermPtr [dbGet ${instPtr}.pgCellTerms] {
    set pgTermName [dbGet ${pgTermPtr}.name]
    set pgNetPtr [dbPGTermNet [dbGetPGTermByName $instPtr $pgTermName]]
    # Check connected net
    if {$pgNetPtr == "0x0"} {
    set pgNetName "0x0"
    } else {
    set pgNetName [dbGet ${pgNetPtr}.name]
    # Sort power/ground
    if {[dbGet ${pgTermPtr}.type] == "powerTerm"} {
    lappend pgTermArray(power) $pgTermName
    lappend pgNetArray(power) "$pgTermName $pgNetName"
    } elseif {[dbGet ${pgTermPtr}.type] == "groundTerm"} {
    lappend pgTermArray(ground) $pgTermName
    lappend pgNetArray(ground) "$pgTermName $pgNetName"
    # Return results
    if {[regexp {\-net} $args]} {
    return $pgNetArray($termType)
    } else {
    return $pgTermArray($termType)
