  3. to delete all the io pins in a design and load a new io...
  • Subscribers 93
  • Views 15611
to delete all the io pins in a design and load a new io file
tanvis
tanvis over 9 years ago
hi,
i am looking for the deletion of all the IO pins in my current design and loading a new IO file which has the correct pin location. Need the user guide or the command for this. I tried using deleteIoInstance - with which we will have to give a string in order to delete all the IO pins.
Please also point me to the INnnovus user guide.
Regards
Sar
  • kazad
    kazad over 9 years ago
    Hi Sar
    I assume you want to unplace the existing pins and load a new IO file. If that's the thing you are after, you can try the following procedure:
    # Procedure to unplace IO pads/pins
    # Usage: unplaceIOs {-pads | -pins}
    proc unplaceIOs {args} {
    unlogCommand dbGet
    # Select IO pads/pins
    if {[regexp {\-pads} $args]} {
    dbSet [dbGet -p top.fPlan.ios.inst.cell {.baseClass == "pad"}].pstatus unplaced
    } elseif {[regexp {\-pins} $args]} {
    # Unplace pins
    dbSet top.terms.pStatus unplaced
    # Delete associated metals as well
    deselectAll
    foreach pinPtr [dbGet -p top.terms.isSpecial 0] {
    # Unplace pins
    dbSet ${pinPtr}.pStatus unplaced
    # Get metal layer info
    set layer [regsub {[A-Za-z]} [dbGet $pinPtr.layer.name] {}]
    # Get box info
    set box [dbGet ${pinPtr}.pins.allShapes.shapes.rect]
    if {$box != 0x0} {
    set x1 [lindex $box 0]
    set y1 [lindex $box 1]
    set x2 [lindex $box 2]
    set y2 [lindex $box 3]
    eval selectPhyPin $x1 $y1 $x2 $y2 $layer [dbGet ${pinPtr}.name]
    # Delete selected pads/pins
    deleteSelectedFromFPlan
    deselectAll
    redraw
    Khandaker
