  3. multiple cells - single layout
  • Subscribers 93
  • Views 1678
HansRey
HansRey over 9 years ago
I have 3 cells with each their own lib-model. Since the layout of the combination of these 3 cells is very critical, I would like to use a single layout for the combination of these cells.
So in my netlist I would have something like this:
CELL1 u_cell1 ( Y, A, B)
CELL2 u_cell2 (X, C, D)
CELL3 u_cell3 (Z, E, F)
But In layout I would like to use a single cell CELL123(X, Y, Z, A, B, C, D, E, F). Making a single lib-file for this cell is not feasable due to the timing dependencies between A, ..., F
Anyone got any advice on how to handle this?
Kind regards!
  • akshay gupta
    akshay gupta over 9 years ago
    Can you please elaborate "due to the timing dependencies between A, ..., F" . I am not able to get which timing dependencies will the .lib miss.
  • HansRey
    The main problem originates from the fact that I want to use a flipflop and a latch in a single cell. This construct is not allowed in RTL Compiler (except for scan flipflops or register banks).
    Also, characterizing a cell with fliplfop+latch takes a lot more time than just characterizing each cell seperately. The number of possible inputs increases exponentially when I combine the 2 cells in a single cell.
    Another reason why I would use multiple cells in stead of a single cell is the complexity of a single cell: I have a lot of signals which are creating pulses / are timing dependant on some inputs, which means the function can not easily be defined in a single cell...
